Heater Dust
zeefarid
HI
I HAV A 98 GLS AND RECENTLY WHEN THE CAR STEAMS UP AND I USE THE FAN DUST IS RELEASED
AND IT STINKS. AFTER A WHILE THE DUST DISAPPEARS BUT THE WIND SCREEN DOES NOT
DEMIST INSTEAD IT BECOMES MORE DUSTY. I HAV LET THE CAR HEATERS RUN BUT THE PROBLEM
DOESNT GO AWAY. I CANT REMOVE THE CONDENSATION FROM THE WINDSCREEN.
HELP PLEASE
THANX
The dust might be a dirty filter.
The best way to demist your windscreen is to use the aircon rather than heat, if your aircon works well, it should only take a few seconds and it will all disappear.
Hello :thumbsup:
As said above whip out your cabin filters (x2 of them) and replace with new ones theyre probably filthy and clogged up which would explain all the dirt/dust and the poor strength of the blowers trying to clear the windscreen.
Give this a read it tells you where you need to be looking in your car and where you can sorce the new filters from, http://toyotaownersclub.com/forums/index.p...hl=cabin+filter
Mick.
