Avensis T3s Idling Speed / Avensis Service Manual
esox
As a new Avensis owner can anyone tell me what the idling speed of a T3S should be when it's warmed up?
Is there a service manual available for the Avensis?
Not sure if engine model makes a difference-do you have a 1.8, 2.0, petrol or diesel, auto or manual?
My 2.0 T3-X auto idles just under 1000, say about 900rpm when nice and warm and not in gear.
from memory
600~650rpm-ish for manuals
800~850rpm-ish for auto's
when cold a lot higher though
Mine ticks over around 650-700 when warm. Has you said when cold mine has been ticking over around 1900 rpm.
My 1.8 auto is about the same when warm - 600-700
HI there I find my 1.8 vvti tickover speed when cold frightenly high
however when warm is about 800 rpm
kaffakkaf
kaffakkaf
It's to speed the warm up of the engine and cat.
Better to warm it up quickly with a high cold idle then let it idle at a low speed and take forever to warm up
:) Thanks for all the prompt replies. My 1.8 T3S also ticks over at 650 rpm. I had 10 years of a 1.8 Carina which had one persistent, but intermittent fault - a sticking accelerator cable - which meant it sometimes revved at 1000 rpm instead of 500 rpm even when warmed up. When I found my T3S ticking over at 650 I wondered if I'd got the same problem I had with the Carina. Thanks to your help everything seems OK.
Actually mine settles around 600rpm :)
