Dashboard Light Question...
I've just modified the post I put down before, really need Ryan or someone else in the know to put things straight. I know the existing pipe can have the car removed, but it could have expensive consequencies should your car subsequentially fail it's MOT on emissions.
If you look at
http://www.fensport.co.uk/parts.htm
they have a Blitz decat pipe for the turbo at £231.00 though - expensive stuff indeed.
The light usually indicates a CAT issue, generally that it has melted into a ball and is blocking airflow but obviously this isn't the case for you - is the temp sensor still in there or has it been removed?
Just found this on the IMOC site - could be a dead cat you have :(
Do a forum search on IMOC with keyword decat. The message is the post titled " [MK2 Turbo] Nightmare!!"
On the plus side, it sounds like you can get a garage to remove your cat, as long as they know what they are doing. You should be OK with emissions - but the engine and turbo need to be in good condition.
how much would a new cat / repairing the cat cost from Mr t ?
Hmmm, not totally sure, but I reckon you will be looking at £300+ cats are not cheap. However, you could see if you can find one from a breakers yard. You will find contact nuymbers for Club MR2 and Toyota Celica breakers at http://www.imoc.co.uk
oh well then... I'll just get the bugger de-catted then...
May as well instead of prob paying Mr Toyota £££ to do probably nowt...
Any idea how much it would cost to get the cat removed from a garage somewhere ?
you won't get a mot without a cat!
yes I will... it's a 1990 turbo.. should pass fine ( shouldn't it everyone ? )
The company I bought the car from said this .....
"The cat has probably gone lazy (lack of use ) it will come right, Subaru's do it all the time.
We took the cat out of a friends MR2 what a difference, you have to do this ."
So could it be possible that it could be "lazy" ?? If so any idea when the bugger will "wake" up ? Any info on this greatfully received !
thanks
