Avensis T3-s Cigarette Lighter Socket Dead
Muarrif
I own the Avensis T3-S 2003 Model.
The Cigarette Lighter Socket located at the front middle is not working. I can not charge anything and also the lighter does not work. The socket seems to be dead completely. I suspect the fuse is probably blown but have no idea where the fuse box is located or which one to check.
Any help would be appreciated.
Many Thanks
I would presume that all Avensis's have standard user manual if you do not have your manual then the fuse panel is located behind the glove box and is a 15a and as you look at the panel it is lefthand column and is 9th from the top (number 40)
Carday I would assume that a new member would ask a question for a reason, especially as this is a Toyota Forum and we are supposed to be here to help each other after all, but then again I may just be mistaken !!!
Muarrif welcome to the club, any questions feel free to ask away :D
