Avensis T3xd4d Sat Nav
tkerr520
Hi All
I hav a new 06 Avensis T3x I was wondering if I could fit the TNS 300 sat nav easily to the existing head unit without having to dimantle and connect equipment I can see some plugs etc under the passenger seat and was wondering if thats what they are for
I know the older version of the T3X requires wiring to be connected to the loom behind the radio etc
Can anyone Help
Thanx in advance
Tom
I'm about to get an 03 reg T3-X, and like you was wondering whether to fit a TNS300 sat nav in it. I'm pretty sure you'd have to take most of the dash off to fit that. I've decided it's not worth the bother, and will probably get one of the new TomToms instead http://www.tomtom.com/products/section.php...&Language=1
(they do a UK only version too, which is cheaper) I'll have to take it out every time I park so it doesn't get nicked, but it's very small and the other side of the coin is that you can use it in other cars, tell it where you want to go before you get in the car, and plug it into the PC with a USB cable to update it.
