New Dash Speaker - Help
S.Kayani
Hello guys, managed to pop my passenger side dash speaker some how lol (makes a pop noise if too loud on bassy tracks)
and was basically just checking if these would fit
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=220022908902
i need to get some replacement ones for as cheap as poss!!
the ones i got in at the mo sound quite good and bassy so dont reali want to make them any worse lol
let me know what you think! :thumbsup:
Yep - should fit - they're just 10cm cones. You may need to alter the mounting holes slightly but I| doubt it.
When I did mine I extended the wires a little to make my life easier
- hope that helps
On mine i had to cut off two of the mounting holes on the speaker to fit them in but it was a really tight fit after which is what you need for no annoying vibrations!
Mine only have one bolt in and the other attachment eye like wedged against something and both hold fine and don't vibrate :P It's easy enough to do tbh!
they should be coming tomorrow - maybe the day afta, ill let you all know as soon as ive fitted them
luckily you are able to snap off 2 of the fittings if you dont need all four
edit - wtf sr kid you paid £99 for your theloudest.com dash Speakers?
they must be good!
cool cool
fitted them 2day, pretty easy to fit, clearer then original, slightly more bassy - i think the orinal ones are 12w RMS these are 20W RMS
id recomend them - worth it if your on a budget...like meeeee :-D
lol yea, if your changing them because you need replacements, these are brilliant
if your changing them just for the sake of it, it would be better to spend a bit more and get some better one like theloudest.com one
i think they are around 50W rms
