Thermostat Location
1991 n/a 3sge , i think near the oil filter , anyone correct me on this . thanks
anytips on changing it , looks like a bad job , givin its location .
my tick over runs at just under 1k static , but when i drive again the temp guage drops and tick over rises to 1200 , its not good is it
It's on the drivers side of the engine near the exhaust manafold.
Easy job :thumbsup: the hardest part is bleeding the sys when you are done.
Have a Lookie here about bleeding. It's the same on all mk2's :thumbsup:
You can also Lookie Here under Cooling to see what to do with the thermostat.
Hope this helps, Paul. :thumbsup:
thanks paul , i fitted a new rad a week or 2 ago and had to bleed the system then . mr2oc had all the info . must say without the info i'd of been stumped.
