hey i know everyone keeps going on about this but can i just confirm with people the correct sizes.
14inch - 195/50/14
15inch - 195/45/15
16inch - 195/40/16
are they the right sizes?
thanks matty.
recommended fitments,
14" 185/60x14
15" 195/50x15
16" 195/45x16
17" 205/40x17
I thought the recommended fitments are
14" 165/60/14
15" 195/45/15
16" 195/40/16.
14" 165/60/14
15" 195/45/15
16" 195/40/16.
they are... ;)
Lots of factors come into it.. especially with going to a bigger size. Use the above sizes as a GUIDE only.. check with your retailer before buying... but both sets are recommended sizes.
well what is the differnece between the two sizes? sumone said sumit about the wrong makes you speedo go out or sumit?
If you want to keep the standard 14 inch wheels but have wider tyres you can fit 185/55/14, this change will mean that when your are travelling at an indicated 70 mph you will actually be moving at 70.25 mph. You can also fit 195/50/14 tyres and at an indicated 70 mph you will actually be moving at 69.18 mph.
When changing wheel and tyre sizes there are 7 considerations. 1. The wheel size. 2. The wheel width. 3. The ET (offset - how far the wheel will stick out from the body work). 4. PCD (pitch circle diameter) the size in mm of a circle drawn through the centre of you wheel bolts. 5. The number of studs (bolts). 6. Tyre size. 7. The impact the changes will have on your speedometer (indicated) readings vs actual speed.
For 15 inch wheels you will need to buy rim (wheel) size 15x6.5 ET 37 PCD 4/100. In order to maintain the accuracy of the speedometer with this increased size you will need to put 195/45/15 tyres on. This change will mean that when you are travelling at an indicated 70 mph you will actually be moving at 69.92 mph. Alternatively for 15 inch wheels you can fit 175/50/15 tyres however this choice is limited to just 2 tyre manufacturers as this size is not very common. This change will mean that when your are travelling at an indicated 70 mph you will actually be moving at 69.86 mph.
For 16 inch wheels you will need to buy rim (wheel) size 16x6.5 ET 37 PCD 4/100. In order to maintain the accuracy of the speedometer with this increased size you will need to put 195/40/16 tyres on. This change will mean that when your are travelling at an indicated 70 mph you will actually be moving at 70.67 mph.
The recommended tyre fitments are therefore 13" 155/70/13, 14" 165/60/14, 15" 195/45/15 and 16" 195/40/16.
All wheels are offset 35 – 45 and bore 54.1. Offset 37 is ideal.
cool... i think i understand that. thanks for the detailed description! mush apperciated! :)
I didn't.. and i'm a tyrefitter ;) :lol:
:lol: - got the info from your link - nice one :thumbsup:
