Problem With Lights
shawno
Having a problem with the lights on a 1996 Caldina. The lights when on park work (At least the side ones) also when on high beam they work but both lights don't work when in the normal on position. I have checked the fuses and they seem ok (I swaped the main light fuse with one from a Corolla and it worked in the Corolla). Any help/ideas would be apprieciated.
It sounds to me as you might have some fault in the switch. There are 2 wires from the switch to the headlight (normally red/yellow and red/green). Have a closer look at those wires all the way to the head-lights.
Have you checked that the globes aren't blown?
There are 2 filaments in the headlights (1 for low beam & 1 for high beam)
Because the low beam ones are used a lot more frequently than the high beams they blow earlier.
Have you also checked whether the relays are functioning? I can't remember whether they're in the fuse box near the Battery or the one hanging off the back of the radiator.
I had a similar problem when I converted my 96 Caldina to the Morette twin headlamp kit, even thoguh it uses the original globes in the outer 2 headlights. ;)
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
