Hi, just wondering if anyone knew about how to disconnect that annoying bleeping when you stick it into reverse (96 Cynos/Paseo, convertible, 1300 auto) ... it also bleeps (actually a continuous tone) when you stick the key in the ignition and the doors open
either disconnect the wire or disable the beeper
any info would be appreciated ... thanks a lot
When you find it let me know...
The reversing bleeper is annoying. I converted my car from auto to manual but still have the bleep...
1300 Auto in a '96 Seo? Weird!!
I have the beep when the doors are open, doubt you'll be able to disconnect it.
Nice Seo/Cynos by the way! :thumbsup: Is that the Galliano yellow? Got any more pics? :)
u guys are gr8 help, haha ... might have to resort to the local auto sparky, heres some more pics
im not sure what yellow it is, i only got it the other day
one more
Very nice, the convertibles are rare, especially in the UK.
more people might beable to help on Paseopimp.com.
J
well figured it out ... wasnt so hard ... remove panel below steering wheel ... pull out white box (below fuses) which is some kind of relay switch ... the beeper is inside, simply disconnect (however u will lose lights beeper too!)
i just wanted to update this because this will work for the key in the ignition beeper & lights beeper but not the reverse beeper (sorry if i put anyone crook!!)
to disconnect the reverse beeper, pull out the dash panel (pretty easy just one screw & 2 clips). when u get the instrument panel loose, pull it towards you and on the left side there is a white plug. disconnect (or just reach in) and cut the red/black wire - this is the wire linking to the reverse beeper.
so thats what my car will look like without a roof!
welcome to the club cynos-ical
I might have to try that! I hate the lights & door beeper! :ffs: :D
