Strange Buttons
gt4monster
does anyone know what the little rocker switch above the drivers heating vent does nearest the door? its about the size of a 1p and has a little red led on the top which doesnt light up or seem to do anything :g:
It's not a standard switch so could do anything, however most likely to be a rear fog light switch if you've got a import. This is also where the Rear fog light switch is on UK cars only it's a round press button with the rear fog pic on it... :thumbsup:
Try starting the car, put your dipped haedlights on, then flick the switch, should light up then and you will have rear fogs :thumbsup:
If it is a rear fog switch that is :D :P
