Does anyone know if the plastic where the air con button "should" be is able to be modded to be pushed in. I'm thinking about sticking a push switch behind there and obviously need to know if I would be able to use that as a button. Not sure what I want to use the switch for but I thought it would be pretty cool and much better than having a piece of platic there.
Cheers :thumbsup:
When you take off the centre console for adjusting the radio, that peice of plastic is also wired in like the other real switches so there is a high possibility that is can be made into a real one itself.
Really? Is it able to be pushed in? Not got my atgo yet so can't try it out. If not is there something stopping the movement?
I highly doubt this... Mine has the A/C, so I can't be sure, but I think the back
of the cover just has a catch to keep the plug for the optional A/C switch in place.
For car mmanuafacturors it's WAY cheaper to make one wiring loom including wires
for optional bits (like A/C) instead of makeing specific looms for every optional bit...
If you want a switch in that position I'd go to your Toyota Dealer and buy an A/C switch,
fots perfectly and has a built-in indicator light... Might even be possible to remove the "A/C"
printed on with white spirit or something similar (try on the back first to see if it leaves marks!)
So is that something that I can do then. Go into the dealer and ask for little pieces like that? I never knew. Thats pretty cool. Yeah I'm sure theres something that I can get that will get rid of the writing. This is looking pretty promising actually. I'm thinking about putting a kill switch in there for the sub or something like that :D
You should, yes... Tha A/C-button can wear out, causing
you to need a new one, so you should be able to buy one...
Ths is my first Toyota, but for the Nissan I had before my Aygo I've bought some
optional pieces that weren't supposed to be on my spec car without any real problems.
For the Aygo there's only 3 specs: basic, plus and sport (not taking the black into
account as thats a plus with alloys and sills), so there shouldn't even be any problem
with vehicle specs as I had with the Nissan, having a 1.6 engine and wanting parts
for a 2.0 which (of course) didn't match my frame number...
I'm telling you that there is a wire there. So don't say that there isn't. Obviously the good idea would be to go and buy a switch, however the wire is there.
I'm not saying the wire isn't there; in my second
paragraph I've even explained WHY it would be there!
What I'm doubting is whether the plastic
cover could be made into a switch...
probably not.
