Trd Engine And Gearbox Mounts Bracket
please can anyone confirm what Toyota car bracket i need for my car to go with the TRD engine and gearbox mounts? - i have a rev 2 (3SGE) and was previously advised to get:
3S-GE car/bracket (P/N): 12325-74121×1
Bolt (P/N): 90119-12343×1
But when i called up to order this part they said it was for 1997-1999 MR2's??.. my parts guy said the correct part numbers for my car were:
3S-GE car/bracket (P/N): 12325-74120
Bolt (P/N): 90119-10782
so now i'm confused.. do i need the first set of parts or the second set of parts? - does it go on the brackets you are fitting or the car you are fitting them to?.. any help would be great! :wink::lol:
i got some trd engine mounts on mine (brand spankers) but mine is a turbo engine. im not sure what your on about because i never had the problems
it's the bracket for the front torque mount.. i've since found out the answer - the TRD mounts are based on the later brackets and if you have an earlier car you need to buy this Toyota OE part to make the front bracket fit to the bulkhead..
thanks for the reply anway! :thumbsup:
