Advise On Car Check, Pls Help!
YarisGLS
It's a:
3 door T reg Yaris GLS
80,000 miles
Unknown history on timing chain service or drive belts
Unknown history on brake system services
Unknown history on coolent change (I can DIY that)
Unknown history on air filter change (I can DIY that)
Unknown history on engine oil/ gear box oil change (I can DIY that)
There is squeeking noise from the pullies, and some rust around the power steering revesor area. And when the clutch is at its rest position (even when not in gear) I can hear a another small squeeking noise from the gear box area....
So... I need professional advise from you pros here. With so much unknown history of the car, shall I take it to a toyota dealer to give it a good check? Especially on the timing chain and drive belts?
Any good toyota dealers around Leeds/ Manchester/ York area you guys would recommend? And how much will I be looking at for such check/ service?
Thanks a million for your help!
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
