Looking For Some Alloys
Keir
Hey guys, im looking for some 16" or 17" alloys. (have to be black or white :D )
I'd love some like this.. link
But I think the price is just a bit "pla!"
So where you do lot get your alloy's from?
As a sideline, the info you require on wheels will be
PCD (spacing distance of holes for wheel studs size) will be 4x100
offset should be around 35mm - 38mm (37mm seems to be about best if fitting 17's)
Bore size (centre of wheel that 'sits' on/against wheel hub) is 54.1mm
Incidently if you do fit '17's then you will 'catch' on the rear wheel arch if say you are caring more than 3 people/luggage.
Offset is distance of 'hub' part of wheel in relation to 'rim' part of wheel and thus inturn as to how far it sits within the arch (e.g. a smaller offset such as 5mm would have your wheels sticking out from the body work like a 'dune buggy').
well i av had a 2003 corolla and a 2003 t-sport(present car) and on both cars ive put a 42 offset with 225/45/17 tyres.wen i got the t-sport it had 18" rims with a 35 offset and the handling was all over the place!!
have never had any rubbing/ctaching on the rear no matter how many i had in the back with the 42 offset
