Cooler Pump
cecil
Thanks for last info.Cooler pump works when givin alive feed,no signal coming from module,can you tell me were the module is. Can i bypas and put pump on continously
Pump is controlled by the ECU via a relay in the ground path, might be a faulty relay or wiring fault.
Relay Locations
Testing Main Engine relay
Testing Intercooler Replay
