Water Water Everywhere
montyb68
st 165...hay guys it never rains.... after changing the airflow metter for the 2nd time and turned up the boost back to 10 psi it seems to be running fine..
but! on the way home from work we had a water leak.. its taken for ever to find it .. so i ask how easy is it to fix??
its one of the two pipes that are right at the back of the engine under the inlet manfold right at the bottom on a line with the oil filter if you see what i mean..
i can only just see the pipe with one eye if i stick my head right in (o fun!!) looks like maybe lower heater pipes? they go into the cabin but are right low down.. looks like its leaking were the pipe goes into the block
any one know the best way to fix it??
thanks and in hope
simon
thanks and in hope
simon
Probably easier to tackle it from underneath. You might not be able to see it much better but it could be more accessible. :thumbsup:
