Rear Demister Not Working
Handson29
Hi guys,
My rear demister has just stopped working. The light come on on the switch and you hear a relay click but the screen doesn't clear. Nothing at all. Its a 96 UK spec Celica. Where is the fuse for it? Is it the one labeled DEF in the panel under the steering wheel? Any help would be appreciated.
thanks
Iain
Hi Iain,
Just a thought. The same happened on my Avensis. It turned out that a blade connector has actually seperated from the rear screen itself. I tried a repair using a conductive adhesive but it was unsuccessful. I'm dreading the winter months!
Regards,
Geoff
got it sorted today, problem was there is a small connector within the rubber boot that transfers the cable from the car body into the boot lid and that was the broken connection. Guy said it's common in a car of it's age (10years) with a hatch back. Try that if you get a problem, hope it helps someone in the future!
