Adjusting The Handbrake
gt-dust
hey guys,could anyone please tell me how to adjust the handbrake cable on my 1992 gen 5 gt, as ive just had new brake disks pads and a new caliper fitted and the handbrake doesnt hold the car on hills, can it be adjusted form inside the car or only from behind the brake disk itself
thanks
:thumbsup:
I'm not sure if its adjustable in car, but it is certainly adjustable at the shoes end.
there is a hole in the rear brake disc (poss covered with a rubber bung if its still there) and if you turn this so it is closest the floor, and have a look through it with a torch, the turnbuckle adjuster is there, turn it one way to tighten and the other to loosen with a flat bladed screwdriver :)
the full procedure is in the haynes or chiltons, but it really is as simple as that.
You can adjust the handbrake cable at the handbrake. There`s an adjuster nut on the right hand side of the handbrake quadrant. Undo the locknut and simply tighten the adjusting nut. Remember to check the handbrake from time to time. 3 - 7 clicks is ideal. :thumbsup:
Same for Gen 6. I removed the centre console to get to it (hidden bolts at the bottom of centre glovebox) Although I think this is only really for minor-ish adjustments, there isn't a huge amount of play on it. Still, reduced the angle of the dangle considerably :P
