Starlet Ep80 Timing Marks
EP´s
I see its not gonna be easy to find the EP80 wokshop manual, but meanwhile can someone give me a hand? why after replacing the drive belt, check and double check the timing marks of the crankshaft and camshaft pulleys
the idle speed and performance was not riding good.
I know the ignition timing set usually for toyota 1E engines: 5º ± 2 BTDC @ 850 ± 100 RPM. So I used a timing light, and instead of 5º ± 2 BTDC its 23º BTDC?!!! How??? And the engine only rides good with this settings.
PS: I turned the distributor left and right but the with no good results.
Can someone explain me why?
sounds like you're a tooth out somewhere.
There is a timing mark on the crank pulley and a hole in the camshaft pulley that needs aligning with a timing mark on the top end.
As far as I know there's a sticker somewhere on the timing belt cover telling of static timing setup. ( I seem to recall it being something like 10deg BTDC, but don't quote me on that ! )
sorry for the mistake i pushed the wrong box,
I find the sticker very damage, its between 5 & 10 BTCD like you said, i checked the pulleys both align, coud be the distributor?
thanks
