What are some direct bolt in engine swaps for an 88 toyota corolla or swaps that will work, but will need modifications...either or..thanks.
do a search. this has been asked quite a few times before.
..cant find any :(, post a link?
:help: let the BUMPing commence! :help:
u have so many options - it all depends on your budget or how far you want to go. i think the 20v 4AGE is meant to be fairly simple.
you're best trying to speak to dawsey - his car speaks for itself!
You have a few options:
20 valve 4AGE engine swap as mentioned
4AGZE engine swap (supercharged)
3SGTE (dont know if this bolts directly in)
or you could even think about adding a turbo to your current engine block- look at www.turbocorolla.com for help on that idea.
now were cooking, thanks alot....MUCH better :), so is dawsey the screen name or real name? f.i., i'll check right now :thumbsup:
found it!
