How Do I Wire It?
pusseyeyes
I'VE JUST BROUGHT A YARIS SR :yahoo: AND I'D LIKE TO FIT AN AMP. I UNDERSTAND THAT I WILL HAVE TO POWER IT DIRECT FROM THE Battery,. DOES ANYONE KNOW THE BEST WAY TO RUN THE POWER LEAD (AMP) FROM THE INSIDE OF THE CAR TO THE ENGINE BAY,??? :unsure:
You may want to post this in the main yaris section not the Tsport section to get more replies :thumbsup: A haynes manual will help you with removing all the interior panels to run it nicely along the car. Basically from the engine bay it is through the grommets through the firewall by cutting a hole in one and pushing the cable through. From the interior you can pull this inside the car and run under the carpet to do the door sills which clip off. From here through them and into the rear interior 3/4. From there you can run out from under them and under the boot carpet and then up from there where the runners for the rear seats are! Hope that helps! Remember to run the live and the remote wires along oneside of the car and the RCA's along the otherside so as to avoid interference! Also a good earth for the sub can be found if you pop off the covers on the rear suspension mounts in the boot and look down in them where u can see a bolt with a black and white earth cable going to it for the rear lights. Unscrew and add the amps earth eye onto the bolt :D
