Carina - Partial Discharged Battery
Deepak
I have checked the voltage across the baterry terminals and it is 12.47 volts, which according to the Haynes manual means that the Battery is partially discharged. My queries are
1. How to know whether the Battery is a maintenance free or not?
2. Would a partially discharged Battery cause the car to stall abruptly, since it probably is not able to supply sufficient charge required to operate the eletricals after the car is started?
3. How much should it cost apprximately to recharge the battery. I've checked with a couple of local garages and they said they don't charge batteries. Is this something which can be done by oneself?
Any help would be much appreciated.
Thanks,
Deepak
My rule of thumb with a car Battery if generally:
(i) If it runs the starter motor and cranks the car its OK. If it doesn't and it's more than 4 years - time to buy a new Battery. Motor factors have 'load testers' which can usually confirm that a Battery is finished.
(ii) If the charging system is at fault the warning light on the dash will show.
With modern cars using a home trickle charger is unusual. The only times that I have used one is when I've left my lights on and run the battery flat. Recharging a battery which is on its last legs will not help.
Have a read of these:
http://www.topbuzz.co.uk/info/car_battery/car_battery.htm
http://www.shop.edirectory.co.uk/autosave/...&afid=88888
If your car stalls and you are able to restart it with its own battery/starter then I can't see that you have a problem with your battery. The fault lies elsewhere.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
