Clutch
Cexy_Ratt
My GT4 has suppposed to have had a new clutch 3,000 miles ago, receipts etc all there to prove it. But i have noticed if i dab the clutch a little during take off, if i am feeling in the mood, i get a smell of burning clutch, should i refrain from slipping the clutch.
I have tested the clutch by powering up in all gears no slip at all, also selected gears 2,3,4 all simply stall engine when took to biting point, so i am guessing the clutch is fine and my driving manner needs to change.
Also what oils should i get for the transimiion, gearbox, diffs etc... what are good makes
sounds like the pedal needs adjusting (fidley job that requires you to be a contortionist :) ) if its not slipping under load then it sounds ok.
as for gear oils get millers trx 75w 90 it aint cheap but its good quality stuff
