Avensis 2.0 Litre Avensis
umaran
under the bonnet it says d4 it is pertol, what is d4 and for £40 petrol it is giving me 330 miles is that good or bad that is start and stop.thanks
D4 = Direct four stroke
D4-D = Direct four stroke Diesel
ok thanks are there good engines d4
The D in D4 stands for Direct injection. This means the fuel is injected directly into the cylinder chamber during the compression stroke. This means the fuel/air ratio can be varied depending on load of the engine.
The D4 can under certain (rare) circumstances run with a fuel/air ratio as lean as 1:40 which in theory should give a low fuel consumption.
thnk you
