Gearbox Oil
marvinGT4
Marvins having his gearbox oil changed this weekend i have been told to use carlube 75-90 but i have noticed some of you use the synthetic oil. is the difference really that noticable? I havent purchased any yet just wondered what you thought
The synthetic maintains its properties better than mineral. With the added benefit it doesn`t thicken up so much when it cools down and doesn`t thin out too much when hot. Giving maximum protection hot or cold. Gearboxes are notoriously harsh on oil. Makes you wonder why they don`t change the oil more frequently. :unsure:
millers TRX 7w90 top quality oil
thanks for the advice ,hes had his oil change and gearbox oil changed and hes driving like a dream.
great improvement on the gear changing Im convinced its not physcological!
thanks again :D
It's also very important that you don't use a lower quality oil in the ST205 gearbox because it also fills the transer and front diff hence the requirement for API GL5 grade oil.
I'll need to remember this info for when i get mine ready for the nurburgring.. :)
!Removed! ages away yet but sooo much to do! :(
I use silkolene sync 5, covers grades for both gearbox,transfer etc and also rear diff :thumbsup:
What ever you do don't use LSD oil for the rear diff... It's a torsen diff not plate limited slip diff
