Help Please With Fedding Wire Through To Battery !
readbmr
Hi I have a celica 2.0 GTR 1991 J Plate And am having trouble finding a way through from the car to get to the battery+ side, ie im trying to feed the wire through the car to the Battery!!the possitive feed i am trying to get through is from the amp and sub in the back of the boot, ive maanged to feed it through the boot and up towards the passenger well but now am stuck because cant find a hole to get through to the Battery, any help please and hopefully somebody can help me..
Regards from brian
Hi I have a celica 2.0 GTR 1991 J Plate And am having trouble finding a way through from the car to get to the battery+ side, ie im trying to feed the wire through the car to the battery!!the possitive feed i am trying to get through is from the amp and sub in the back of the boot, ive maanged to feed it through the boot and up towards the passenger well but now am stuck because cant find a hole to get through to the battery, any help please and hopefully somebody can help me..
Regards from brian
theres a plug just below the wiper motor cover on the Battery side,if you pull the rubber back there should be enough room for a power cable,just make a small hole in the rubber and run your cable thru then seal it back up. you have to stick your hand up the back of the glove box i think,best to put a wire thru from the engine side then tape your live feed to it and pull it through
Regards from brian
Hi and thankyou for that i will try that tomorrow and let you no how i get on, ie i dont wana pay a shop 30pds for just doing this !! and many thanx again from Brian.
