hey guys, i've been wanting to check with you for ages and its tyre pressures.
I got 17x7.5 on the front with 215/40/17
and 17x8 on the rear with 235/40/17
BBS RCs with Toyo T1Rs
what should my correct tyre pressures be?
What have you guys got it at?
Tyre pressures are a personal thing.. there are rough guildlines to follow, these will be on your car or in the handbook... use them as a guide, then experiment with a few psi more or less till you get it the way you like it.
On my Roadster i have 25psi front and 28 psi rear.
On the wifes old car (MR2 NA) she ran 35 on the rears and 30 on the front as per manual.
When the rears were at lower pressure the car handled really badly.
She was running on 17s at the time
I used to run 28psi front and 29psi on the rears.
Thought the handling was spot on.
