Oil Refill On My Corolla
Meat Loaf
Hello, I have a 91 Corolla Hatchback CSi and I need to replace the oil in my gearbox but I cannot find where the opening is to fill it, does anyone know where the hole is? Thank you. :D
when its a manual gearbox the plug sits up at the frontside in the middle of the gearbox its the same plug as under the gearbox at the deepest point where you can drain your old gearboxoil .
Open the bonnet and look between your Radiator and gearbox and you will see what i mean
