I Know There Pointless But Turbo Timers.....
Cexy_Ratt
I have aquired a cheap TT , its an Ultra Count Down timer. Came with a wiring loom but the guy wasnt sure which GT4 it is for. So what connection blocks should i be looking for undernieth the dash, iginition area to see if it is the right one. I am gonna get a test meter on the timer itself so i will be able to find out what wire does what. Any diagrams or advise on the connection blocks or where to hardwire to on a ST185
if you remove the lower steering column cowling and follow the thick wires that come from the ignition switch, its the large white plug about 4-6" from the switch
