Gen 6 Air Con Removal
Dax
hi everyone, :D
i havent been on here for a while but ive had the bright idea of removing my airconditioning (because i never use it) from my st205 wrc. Can anyone tell me what i need component wise and is it easy enough to do?
kind regards
Dax :thumbsup:
hi everyone, :D
kind regards
Dax :thumbsup:
I did mine ST185. Same setup. Takes the best part of a day if you`re taking out the gubbins inside the car and all the pipework as well. It`s easy enough.
Remove the radiator to give yourself some room, then start at the front with the condensor, then compressor pipework so on and work your way back into the car. No special tools needed that i can recall. :thumbsup:
