Avensis 2.0td Starting Problem
maseyp
hi
My problem is that when the weather turned colder my Avensis 2.0 td 1998 started to take longer to start.
I changed the heater plugs but there was no change.
It then got worse and started to turn over slow. First it sounded like a flat Battery but when I checked the Battery was fine. Then it started to make a groaning noise and turned over very slow.
I have now changed the starter motor and it is still the same.
I have checked the earth cable and that is fine.
I have even used jump leads to make a connection to the starter with the live and the negative to the engine block.
Has anybody got any ideas? mason :help:
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
