Water Injection
blink182
Has any one got water injection fitted to there st205 ?As mine has still got the charge cooler on and wanted to fit it, just wanted to no where people have put the jet and wot size? :thumbsup:
Not fitted it myself but from what I've heard on GT4OC most people who still have the cc drill and tap the mainfold to fit. Not sure on jet size your probably best checking with the kit supplier on that one.
Which kit you going for homemade or Aquamist?
yep drill and tap the throttle body to fit jet. size depends on power/boost run but the smallest one that gets the job done. on a mildly modded car .5 or .6 mm should be fine
