Replacing Toyota Avensis Wing Mirror
bbmad
Does anybody have any instructions or pictures showing how to replace the wing mirrors for Toyota Avensis 1999 vvti (heated and electric)?
Majid
Majid
You will need to remove the inner door panel slightly by unclipping from around the area your working on just so that you can get your fingers in to unclip the heated mirror wire.(near to mirror)If you unscrew the door handle screw this will give you more room to get your fingers in to remove the heated wire clip.
You then need to prise off the triangular cover from inside the car,which covers the three nuts.Which will then allow you to remove the nuts enabling you to remove the mirror.
very easy to do. hope this helps.
Rav :)
Any ideas on how to change the glass on the passenger side wing mirror?
aamir
HI,
THERES ONLY TWO OPTIONS ONE IS TO USE AN ADHESIVE MIRROR TO STICK ON EXISTING ONE.
SECOND OPTION IS IF YOUR MIRROR IS HEATED TYPE. THEN BUY WHOLE UNIT AS TRYING TO REPLACE JUST THE MIRROR IS VERY HARD AND BREAKS EASILY. GOOD LUCK :yes:
  • 2 years later...
Majid
Try www.WingMirrorUK.com they were very good, they fixed my mirror outside my house and may be able to advise you?
