Gen 4 Oil Pressure Sensor/switch
mujaddid
Hi all,
Did a minor rocker cover gasket change this morning and was cleaning around the injector rail as I had easy acess.
All of a sudden my oil pressure guage has stopped, was working fine until today? All other guages working fine.........
Any idea where the sensor/switch is located so I can see if a wire etc has come loose.
TIA
Hi all,
TIA
Its on the distributor side of the head mate quite near the front corner, its kinda round with a single plug the clips on the end. Any probs just take a pic of the head post it here and i will mark it for you.
James
James,
Thanxs, was staring me right in the face, the wiring is attached to a circular contact point, onto wich it clips and must have unclipped whilst I was working on the rocker gasket.
Many Thanxs James.
Hi James,
Dont have a manual yet :-( but you dont know in order from left to right what the 3 sensors are directly underneath the oil pressure unit?
All 3 seem to be water sensors as they are right next to one another, fitted into what seems like a water outlet pipe from block, but dont understand wich one is wich?
TIA
