Yaris Front Indicator Bulbs
johnp
I expect this has been asked many times before.
How do you replace the front indicator bulbs?
Do you remove light unit or access from wheel arch?
Do you have to remove the wheel and plastic mud deflector?
Thanks.
Thanks.
You can access the bulbs by removing the plastic mud deflector and reach for them... Not at easy as it sounds! :)
Thanks.
Just as I thought. Not a 5 min job allowed by examiners. The Verso indicators are easy, but the parking light bulbs difficult. These should be simple jobs. Does anyone replace them routinely during a service?
  • 8 months later...
the casing for my left side indicator just came off in my hand (HONEST!!!! :blush: )
Any ideas how to refix it?
Mr T! (i never do any of that stuff myself!... what can i say? i'm a girl!)
This is why you never see girlie fighter pilots, boxers ,street fighters and bouncers but dont we just love them to bits. :P
If you mean the side repeaters..............they should be a one piece sealed unit.
You could try using some superglue..........good luck
chiz
Or perhaps silicone sealant. I think it may be able to come apart again then, if you need to change the bulb as they cant be changed normally.
