Ok I was wondering if anyone has actually gone out their way to wire in the boot and passenger door switches yet?
If you answer yes to that question then:
What course of action did you take?
If I were to wire an extra switch in I would probably piggyback onto the orignal in the drivers door, does anyone know if this is a push to break or push to make switch? I would have thought it is a push to make but it obviously complicates the situation if it isn't.
It's definately pust to break; it DISconnects ground
for the light with the door closed (the switch pushed in)...
I still have to order the switch, so I can wire it in on my X-mas holidays...
