Replacement Hub Cap
quazi
Anybody recogise this blade style alloy? its a toyota rav4 badged wheel, so must be on record (fitted to 98 reg 3dr GX). The centre hub cap went missing on trip back from new tyre fitting and I cant find any information anywhere. Can anyone give me the name/part reference so I can order a replacement!,
Cheers
Hi Quazi. I had the same problem and lost both the back ones. They are the same wheels as are on mine. I ordered 4 from Toyota dealer as the plastic lugs which hold the spring in place become brittle after time and break off when prising the out. The details on the reciept are as follows:
N/STK CENTRE CAP. Part Number-TPZ406-X0670-1C. Cost £5.45 + VAT Each. Pretty cheap I thought. Hope this helps.
