E11 Dials Help! Pleaseee
hoho15
can anyone give me some instructions for disconnecting the dials from the engine jsut got some G6 dials :>
cheers hoho!
Dude,
Its a really simple job, i take it you have the a who set of dials to plug in....
SImple, make sure ignition is off, theres a front facia with 2 screws and 2 clips you have to remove with the steering adjusted lowest as possible, then the dials are screwed in with 3/4 screws, undo these and the dials will be loose ish, pull 1/2 of it slightly out, put your arm round the back and there will be 3 long plugs with top clips plugged in, unplug em and thats the old dials out...
Hope thats what you were after...
Kamran
cheers bud i knew that part what i ment was disconnecting the wire which turns your mileage, i hope you get what i mean
cheers hoho
cheers hoho
If it's got a cable drive to the speedo then you'll need 'hands like a fiat mechanic' . I can't remember ( on the Sera ) if it's a screw fitting or a clip, although the clip system seems to ring a bell. The cable is pushed into the back of the clocks until it Clicks. There's a small lever/button/tag on the side of the cable that you push in and pull the cable backwards.
( If I remember correctly of course ! )
