Air Fule Mixture Screw
mujaddid
Hi all,
Is there another thread covering this subject or a FAQ, couldnt find one so im asking here.
On the celica's (more so 3sGE) what is the correct method of adjusting the idle screw as mine was altered before I received the car.
Does the ECU need to be put into diagnostic mode via the jumping of the 2 teminals, Battery disconnected for ECU reset after adjustment is made? Or is it just a case of letting it idle once warm and then adjust till correct idle is achieved?
TIA
