Curious About Petrol Usage
ok heres the thing. i have an 1992 mr 2 n\a and according to the guy i got it from u can get 250miles from a full tank.
ive filled mine twice and so far only managed to get 154miles on the full tank.
just curious as to what u guys are getting from full tanks.
could there be something wrong with my car??
any help is great thanks
Full tank on motorway about 300 miles for me..
Round town...
..... gash.
Fuel economy round town, stopping/starting putting your foot down is nasty, even on an na.. welcome to the club!
I can't really remember very well, but I'm sure I got just over 200miles to the tank on my turbo.
On my 1990 NA, I get:
Mainly motorway driving+mixed: 340 miles -> 34mpg
Mainly city driving+mixed: 270 miles -> 27mpg
I think it can get even worse than that if you did all city driving. I'm sure it could go down to 230 easily.
By the way, my car is (apparently) running rich, so I'm sure I could get even better MPG with a nice new O2 sensor!!
15x does seem a little low though doesnt it?
maybe check the break callipers and see if you got one or more stuck on?
thanks for the replies. getting it serviced on the weekend so ill see.
if it is that its running rich how do i get round that?
Your definately not getting as many miles as you should for a full tank. the lowest I get round town is 200 miles but I have had as many as 370 on the motorway.
Anyway, I'd check to see if one of your brake calipers has siezed (a common problem on the MR2 apparently) and also check that your tire pressures are correct.
I dont think the problem will be rich mixture but just to make sure take one of the sparkplugs out and have a look at the colour, if the mixture is rich the centre part of the plug will look black. If you are running rich check the O2 sensor and the manifold pressure sensor.
just pumped my tryes up checked my manual fronts are supposed to be 32 psi and rear 34-36
all 4 were below 20psi :o
first time ive checked em since i got the car a month n half ago.
hope this solves my crappy petrol usage lol
You will notice a massive difference in handling too!
I run 28 on front and 34 on back.
Yep, I'm pretty sure that was the problem then. My tires usually need a top up about once a month so its worth checking the pressure regularly.
i think i got 29 on front and 31 on the back, but gosh 154 from a non turbo? i get around 180-200 a tank with just round the town driving, havent really tested it on motorways yet but im sure it will go down just as quick lol.
