Sticky Stuff
TCGT
hi,
Is there a readily available tape or product that will stick the plastic side trims back on the Celica Gen 5.
Just sprayed them off the car.
They originally had sticky foam, is this available as a tape?
thanks in advance.
I used double sided sticky tape foam backed stuff, needed to stick mine on for a car show 2 years ago, and they are still on the car.
PLEASE NOTE how good I was in this thread.
I think that's the same stuff as what's holding it down origionally?
when I had a door / wing repaired it was replaced (stuck back on) using some sort of car body mastick (spell check) like silicone sealant type stuff. Lasted a few years so far with no problems.
The choice sir, is yours :)
its called trim tape. you can buy it at halford or anywhere that sells body repair materials
