Avensis Battery
sisaven
Hi, Everyone, Christmas Greetings to you all :yahoo:
I will shortly need to Disconnect and change the Battery on my - 2002 1.8 vvt Avensis Vermont - ZZT221 eng.
Does anyone know if the radio CD unit has a security code, - or any other code or Misfortune that might occur on Disconnecting the Battery?? Good Health & Cheer to you all :thumbsup:
Should be no problems. There is no code for the radio as long as its the original head unit. If you're worried there is a little tool you can get which goes into the cigar socket with a 9v Battery to keep the memorys for radio's and ECU etc.
