Rear (?) Wheel Squeak
rallybunny
Any idea what could be causing one of my rear (I think.....I'm terrible at being able to tell where scary car noises are coming from) wheels to squeak?
It happens when I first set out from being park up, at slow speeds, and is like an "eekeekeek" as the wheels are turning, gets faster with speed.
I hope it's something cheap, or not serious. :huh:
jack the back up and turn the wheel by hand. you should be able to get a better idea of whats going on then.
i should think it'll be a binding brake or wheel bearing issue as theres nowt else that spins.
I had that twice, first time I found out the brake dust cover was rubbing on the disk, second time I found out the pads has worn out, most of my friends with this problem found it was worn pads.
