Abs
Phil Bialick
Does anyone how to see if your Celica has ABS or not, apart from the obvious braking hard to see if it skids.
Check in the engine bay by the drivers side wing, next to where the windscreen washer bottle is.
Is there a big metal box with a load of pipes coming out of it and an electrical connector on top, this is the ABS actuator unit. If it's there you have ABS if theres an empty space you don't :thumbsup:
Oh and the more obvious is there an ABS light on the dash, should come on when you power on the ignition then go out after starting the engine
