Help Gen 4 Stereo Fitting
mujaddid
Hi all,
Just purchased a pioneer headunit and tray/box to facilitate the double din scenario. Headunit is a tad larger than dash facia.
Slight modding will be required for neat access to head unit as the tray/box is a prefect fit.
My wiring is a complete mess as the adaptor has been historically cut, I need some help in identifying wich wires are live. GRD, etc......
TIA
Do you have a multi-meter or voltage tester?
If you do its easy to find the ground, live and switched live wires. Speakers are easy too, using the continuity test on the meter on two of the wires should cause the speaker in question to crackle.
sorry i dont as at the mo, but have one of the live circuit testers but just just eliminates several wires like Speakers.
Speakers arn't the main prob its the live grd and mem wich are key.
TIA
sorry i dont as at the mo, but have one of the live circuit testers but just just eliminates several wires like speakers.
TIA
PM sent
The wiring colour code is not identicle, almost all wiring has gre stipes?
