Disabling The Beeper (rear Gear) On A '99 G6 ?
JeeZzz
Hello everyone, I'm new here!
I just bought a '99 G6 (my first car!) and I'm installing a Parking aid kit in it: I'd like to disable the beeper that engages when switching to the rear gear, where is it located (or if there is a fuse or a wire somewhere)?
Thanks!
basically on the back of ya clocks theres a blue denso buzzer just unclip it and problem solved
Thanks, do I have to remove the speedo cable to do that (and if so, how do I locate it?)?
basically i find the easyest way to do it is put your steerting wheel as far down as you can,
pull the plastic surround off
undo the screws so the clocks are loose
remove your headunit pod and go in from there as i found i got alot more room
the speedo cable is easy to take out just pulls and theres 4 plugs at the top
