Speakers Help!
w_ahmed_18
Hi, I have a 2005 Yaris Colour Collection (1.3l). I have replaced the HU (Alpine 9855R) using a ISO adaptor from Halfords. Have bought a pair of alpine 6 x 9 Speakers and don't know how to fit them, I still want all the front four Speakers to work.
Please could you help me in how to install them to the HU?
Thanks in advance!
you can splice the rear wires so that the rear output from the HU powers both the doors and the 6*9s. However by far the best method for your set up is to run both of the door and dash off the front speaker outputs and then the 6*9s (which require more power) off the rear outputs. You can splice the fronts to accept the doors aswell OR get a toyota green loom (i think around a tenner) which allows you to plug two sets of Speakers into the fronts socket which is much tidier, plug n play n means easy reversal when you sell up!
If you need any more information on this do a quick search :thumbsup:
Yup as it goes on the toyota end of things which plugs into the ISO as far as i'm aware! Im sure someone can confirm that!
