Vitz Rs Turbo
de_niro69
hi guys just after some info on the Vitz Turbos,
are these only available in Japan?
do they only come in a 5 door?
what size engines do they come in?
what is their Vin numbers?
what year did they start from?
thanks in advance
1. They are available in Finland & Switzerland as well
2. No they come in 3 door as well
3. Only come in 1.5
4. Not a clue
5. Started as far as I know from when the phase 2 started so in 2002 sometime
3. Only come in 1.5
Unless you can find one like this 1.3 Turbo Vitz RS
Apparently before a certain age there were 1.3 and 1.3 Turbo Vitz RS's but this is just what I have read on the internet don't know if thats 100% correct
That link doesn't work mate
And as far as I know, they only came in a 1.5. Living here where Japanese imports rule, i'm sure i'd have heard or have seen one by now, but not heard or seen anything of a 1.3
Wow, they appear to know absolutely nothing about Vitz RS's...
EDIT: Oh and you'll also note that the 1.3 has a bolt on HKS Turbo ;)
Ach well still a 1.3 Turbo all the same :lol:
But why the **** is it a 1.3 Vitz RS did they make them but with a higher tuned engine then go on to make 1.5 Vitz Rs's
:huh:
Anyway still looks cool and would be fun to drive.
RossP and others-
thanks for the quick reply-
is your Turbo a Jap Import?
if so can you check your Chassis plate in your Engine bay to see the Number
if memory serves me correct then it should be something like this
NCP10 xxxxxxx or so
cheers
D
