Replacing Brake Discs On V7
slamplug
Does anyone have instructions for replacing front discs on a v7 celica. More than anything i just want tomake sure I have the right tools before starting.
Cheers
Do you mean brake rotors? A good set of metrics should do the trick. And A brake pad spreader would help. Available at most auto parts stores.
  • 3 months later...
17 mm to be exact and the calipers come off with two bolts per side, then the rotor practically falls off, Have fun, it really is that simple.
